Hello all- 2014 Typhoon 4t4v
Hope some of you might be able to help me. Just upgraded to malossi 80cc, now it won't run right. If I try revving the throttle, it would bogged then died if held on to it. Let it go it come back idling. But if I throttle it slowly, it'll get to like 60% then bogged. Check for leak with carb cleaner, no leak.
Have tries the following but get same result
idle 35 35 35 42 42
main 75 88 88 88 88
needle mid mid top mid top
mixture screw is at -2 or -2.5 depend on idle size.
I am ready to tap out, any suggestion is appreciates!
