150 Super 1978
150 Super 1978
I want to put in a rubber Corteco into one of my old cases. But it seems it's stubborn.
It doesn't line up flush with the case
No matter how I whack it with a large washer I can't get it flat at 2 o'clock it just sticks out.
Jet Eye Master
Jet Eye Master
If you take it out it will be trash. I doubt it tore as it went in. Most likely fine. If it doesn't rub on the crank, run it.
Bigger concern is those casings have had a hard life. If they pass a pressure test first time, it's your lucky day.
@frank_n_stein avatar
Jet 200, P200E (x2), T5
I'd bin it, and fit a viton seal instead. What with all the ethanol I'll be dealing with in its lifetime.
[ Time: 0.0071s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
