My 2013 GTS300 (non ABS) will not start.
I found the MV Wiki and identified that the error code (C) indicates a break in the wire between the key antenna and the ECU.
Has anyone had this problem and managed to repair it?
The wiring loom is not available as a replacement part, so a repair will be required.
Any advice please...?
