@utahusker avatar
2024 GTS 300 SuperSport, 1980 P125X, 1974 V90
@utahusker avatar
I had the worst thing that could happen involving the keyless remote on my new GTS Super Sport. I was riding yesterday and the low gas light came on, so I pulled in to a gas station.
I pushed the seat unlock button, but no go. I then felt my pocket and my fob was nowhere to be found. I called an Uber to get home so I could locate my fob. It wasn't in my garage so it fell out of my pocket somewhere Facepalm emoticon .
In a panic I set out to follow my route, which luckily I remembered it well. Incredible since I'm an old bastard. I drove through most of the route with a high heart rate. Low and behold I saw my keychain on the side of the road about a mile from the gas station where my scooter was stranded. I pulled over and put my 4 way flashers on. I picked it up and all the was on my keychain was the empty outer shell after being drove over by cars, nothing more. I kept looking while dodging cars and trucks. I found the circuit board which was slightly bent, then looked hard and found one button, then the other. While walking back I found the silicone piece that holds the board in place. The only thing missing is the aluminum end piece.
I then drove to the gas station where I left my Vespa. I reassembled the the remote in my car and tried it out. It worked!!
The only thing that doesn't work is the remote seat unlock.
My question is, how do I reprogram another remote without taking it to a dealer? I have no dealers close.
Sorry for the mini novel, but I feel very lucky.
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
Replacement '23 Vespa Remote fob
European part number: 1D004008
North American part number: 1D004096
Different SKU indicates a different part (possibly due to different radio technology or local approvals)!
Passive mini-tag (Master) required to teach-in replacement Fob! According to AF1-Racing, programming can only be carried out by a dealer with PADS: https://www.af1racing.com/prodimages/st3/1B004096_d7.pdf
There's a reason "old-fashioned" ignition keys can't be removed without turning the vehicle off. That way you can't lose it while driving...
While we were in France last year, I saw a PTW rider pass me, with the remote control and top-box key on a ring in the top-box lock. Disaster waiting down the road...
@utahusker avatar
@utahusker avatar
It's weird that you can't program a spare remote with the master tag. Instead it looks like you need the PADS software, which is available to dealers only.
Vespa GTS 300
Vespa GTS 300
You need both: Master and PADS!
2019 GTS 300 HPE w Malossi
The programming requiring PADS makes me think of the crap from John Deere ...
Which is fine almost anywhere in Europe, where dealers are rarely that far away - but in the US, where you can be 400 miles or more from the nearest dealer it seems punitive.
Vespa GTS 300
Vespa GTS 300
There's a reason why "new-fashioned" ignition keys cannot be locked in the vehicle (pet carrier). This way you save a lot of trouble and many hundreds of posts here on MV...
It's a sad thing that technical innovation always seems to have a negative connotation for some people. Not everything new is bad, not everything old is better. Nothing is as constant as change.
Vespa GTS 300
Vespa GTS 300
Its not a bug, its a feature…
Try Australia
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
I've been wondering if a blank Piaggio chip key can be cloned to the remote or the supplied"chip coupon"? I was thinking that pressing the RFID chip against the legshield would be a suitable lower cost alternative to carrying and losing the fob or the chip coupon. As a bonus, the key could be cut to fit the top box.
[ Time: 0.0125s ][ Queries: 3 (0.0037s) ][ live ][ 343 ][ ThingOne ]
