Doubtful of the value of replacing the oem with an aftermarket one.
(No, I'm not interested just kept seeing them on Instagram)
2019 GTS 300 HPE w Malossi
Posts: 9070 Location: Batmania aka Melbourne, Aus |
Posts: 2149 Location: Oceanside, CA |
I'm not gonna lie, that Maru's Factory one caught my eye and had me make a trip into the garage to assess the OEM.
The Vespa branded OEM cover seems like a classic design element that would be missed if it was replaced with an aftermarket option. That being said, I have a SIP front hub that I'm eventually going to put on and it might be fun to swap the front swing arm (it is a swing arm, right) as well. |
Posts: 15122 Location: The state of insanity, SoCal |
this job is a pain in all nine assholes.
buy two sets of bearings because you'll wreck the first ones. you'll need the special tool so you don't wreck the parts or the fork. and a press. and the fork has to come out. |
Posts: 7713 Location: Madison, Wisconsin |
greasy125 wrote: this job is a pain in all nine assholes. buy two sets of bearings because you'll wreck the first ones. you'll need the special tool so you don't wreck the parts or the fork. and a press. and the fork has to come out.
Positive
Positive
There's one way to find out how good their R&D is. Piaggio likely broke more than a dozen while coming up with the design. Not so sure about all these guys. Fortunately, it's not an important part of the suspension, and if it does snap when you hit a bump, you should be fine.
Motovista wrote: There's one way to find out how good their R&D is. Piaggio likely broke more than a dozen while coming up with the design. Not so sure about all these guys. Fortunately, it's not an important part of the suspension, and if it does snap when you hit a bump, you should be fine. |
Motovista wrote: Fortunately, it's not an important part of the suspension, and if it does snap when you hit a bump, you should be fine. |
Some Vespa, some Yamaha, some Suzuki, some Kawasaki, some BMW, some Honda...
Posts: 296 Location: Hamilton, Ontario |
Greasy, the factory tool makes it possible to remove insitu while still being a pain in all 9 assholes. Sadly, the wobble is not guaranteed to go away if rear bushings are worn.
Posts: 11768 Location: Hermit Kingdom |
SteelBytes wrote: No but there are always people who doubt things written here |
pullmyfinger wrote: Greasy, the factory tool makes it possible to remove insitu while still being a pain in all 9 assholes. Sadly, the wobble is not guaranteed to go away if rear bushings are worn. nothing like rolling around on the floor with a wobbly-bobbly scooter while strong arming a press tool. it only gets better when it's up on a lift teetering precariously and threatening to fall on you thus taking all the profit out of the job with a ER trip. |
