Can someone help me with the problem I have with my new clutch.
I installed a new Cosa clutch in my Vespa sprint 177 Vmc and I'm struggling to get it to work. I have put the normal clutch washer with a 1mm spacer shim. When I pull the clutch in it will go into gear but when I let the clutch out it just bangs forward and stalls. If I only tighten the cable up to the pull leaver and don't manually pull the leaver round before tightening it won't even go into gear.
Any advice would be appreciated.
