Howdy. I've reached the final steps of rebuilding my once-derelict 1980 Vespa 100. Along the way I switched to an electronic ignition stator and all-AC.
I was told the stator I received is an ET3 stator. I was expecting (in addition to the red, white and green wires going to the CDI) to have one power output wire and a ground. Instead, I have THREE wires on the output side: blue, green and black.
I'm sure black is ground, but what's up with the other two? Are they both 12 v output? My super-simple wiring loom is designed with just one wire bringing power to the switch. But I think the stator is giving me two.
I am no electrician. This will become obvious by my next question: If I just twist the two stator output wires together, will the result be 24 volts? Or just 12 volts with more amps?? The first of those options would be bad, the second good.
If it had just one power wire coming off the stator, I could proceed with confidence. With two wires, I'm not completely sure wassup. If I have a second power wire, I might use it for indicators. The loom is set up for them, but I'll get to them later. This is my first Vespa and, for now, I just want to get it up and running.
So I get what to do with a ground and one wire. But what should I do with a ground and two?
Grateful for any wisdom. Thanks.
