Just passed 40K on NelliBee, my 2013 GTS, woohoo! Here's the scenario: after an hour long ride on secondary roads, I stop for fuel which takes, what, 5 minutes. After saddling back up, I push the start button. The starter just begins to crank, then, like a skipped heartbeat, it hesitates, then continues. Engine fires right up.
On a couple of occasions, the starter didn't even start to crank, just nothing. But on the second attempt it cranks, maybe with the hesitation, and the engine fires right up.
Brought the battery in, less than a year old and still under warranty, it tested just fine. Meter testing of the scooter on start, etc, all within normal ranges.
So, the starter hesitates when the engine is hot, never when starting cold. I have yet to meter it when hot, that's next. Any clues here to what might cause the starter to hesitate?
Thanks for your attention.
