GTS 250('13) PX200E('84)BMW R25/3('52)
Hello,
I own a GTS 250 IE with approximately 60,000 km.
I have been with him for about 8000 km.
Since I have it, I can travel 120-130 km with 1 tank of gasoline.
Fuel light comes on at 100km.
I know this is not normal so I had the valves and engine checked.
Circulation and oil pump have been completely renewed.
Which part do you think I should be suspicious of?
Gas pump?
ECU?
Many thanks!
How much petrol do you add after going 130km?
znomit full of tank
@jkj-fz6 avatar
BV400, Primavera 150
@jkj-fz6 avatar
Tire pressure checked regularly?
2019 GTS 300 HPE w Malossi
fuel level sensor
@wbdvt avatar
@wbdvt avatar
erdiba wrote:
@znomit full of tank
Liters?
wbdvt wrote:
Liters?
Or even - litres?
We need to know the volume of fuel per fill-up, as well as the distance travelled.
Thanks for answers!
znomit Full of Tank around 6-7 Litres
JKJ-FZ6 yes 30-33 psi
SteelBytes is it causing high fuel consuption? because im fulling my tank and with 6-7 litres i can travel only 100-130km
wbdvt yes litres
jimc 7 liters 100-130km per full of tank.
GTS300 -20
GTS300 -20
What about air filter, spark plug?
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
I believe the tank capacity is 9.2 liters. The low fuel warning light is a bit premature.
vspadrivr both totally new.
NightWing its around 8 litersi think.
Update: Faulty oxygen sensor renewed with original part. but still same.
@jkj-fz6 avatar
@jkj-fz6 avatar
Leaky fuel line or tank? Can you smell fuel?
@nightwing avatar
Contributor
Contributor
@nightwing avatar
Our WIKI lists it at 9.2.
@clampett avatar
@clampett avatar
Seems like it is running well and everything is ok except the range/liter.
Has done it since purchasing new.
Sounds like the previous owner has added performance mods.
Clutch/variator not stock and/or some other performance upgrade(s).
@nightwing avatar
Contributor
Contributor
@nightwing avatar
He may just be filling the tank shortly after the light comes on, thinking it is nearly empty.
This. I'm lucky to get 1.6 US GAL in when the light comes on - that's ~6.3 litres.
That's a 'reserve' of nearly 3l, not the 2l the manual says...
@jkj-fz6 avatar
@jkj-fz6 avatar
I suggest recording the exact amount of fuel used and the exact distance travelled, over the course of three or more fill-ups. That way you can get a more accurate measure of fuel consumption which you can compare to consumption after you've made a change.
Nobody is going to mention the 250 engine in a 2013 bike?
I don't know the rules in Turkey, but in some places the date of a vehicle is from when it's first registered, not the 'model year'. So this could have been hanging around in a dealership for three or four years.
A quick look at the 250 models in the selector on SIP's website shows through to 2014. (Including a viet made vin prefix for some)
@clampett avatar
@clampett avatar
It was mentioned in the first post Razz emoticon
(I couldn't help it, please don't use the hammer!!!)
[ Time: 0.0094s ][ Queries: 3 (0.0028s) ][ live ][ 343 ][ ThingOne ]
