So I'm looking at buying a three port 8" engine to build for my VBB.
How much is a complete engine worth?
How much is a complete engine worth? |
Posts: 15121 Location: The state of insanity, SoCal |
Grumpnut wrote: So I'm looking at buying a three port 8" engine to build for my VBB. How much is a complete engine worth? so you'd be looking at sprint, etc and P125/150 as well as LML and converting them. with engines, condition is everything. the more complete the more dinero. figure something rebuildable is probably 300~500 pretty easy and it just goes up from there. |
Posts: 10598 Location: Hustletown, TX |
greasy125 wrote: to my knowledge nothing 8" ever came with 3 ports. maybe a really really late super?
Positive
bodgemaster
Posts: 7851 Location: So Cal |
Posts: 10131 Location: Ballarat VIC, Australia |
Birdsnest wrote: Yes the 2nd generation supers were 3 port as I recall. So, any vbc after ~76. |
Birdsnest wrote: Cool. So 3 port after sometime in 1975. I know on the 74 cases (or at least the ones I've seen) there's the meat for the port, but it's not cut. |
I had a 74 that I was able to add a shallow third port to. there was plenty of metal still left, but I did not to break thru and have to resort to filling and recutting.
greasy125 wrote: ...provisions in the case for the main seal on the crank side and not the clutch side of the bearing. |
MV Santa
Posts: 5009 Location: Sedgwick, Kansas |
MV Santa
My 76 VBC has a 3 port case but came with a two port cylinder.
I am running a Pinasco 177 3 port cylinder kit. |
Couple of old cases that came with my VBB
VBB1T case (left) and VBC case. Both 2 port. The VBC case has 2 pins for the rear brake shoes. The inlet has has the factory keyhole cut on the inlet. VBB case does not. I think it was the original engine.
Posts: 5108 Location: Australa, Mate |
VBC2 had 3 ports, and probably something like an Indo P150S would have had a mysterious motor.
Dunno what it's worth. Otherwise you could use a VBC1 & add a bitta-phat then grind in a 3rd port. |
Well I'm now in possession of a complete Super engine and fork for $140. Plus the $100 in gas and six hours in the car. Photos forthcoming once things are cleaner
