I have a 76 VBC Super that I have kitted with the following:
Pinasco 177 alloy cylinder, piston and head.
S.I.P. Road 2.0 exhaust.
Clutch upgear.
20/20 carb.
Air corrector 140.
Atomizer BE4.
I started out with a 116 main but that was was way too rich. I came down to where it is drivable but still a little rich.
Top speed on the flat is about 56-57 mph.
I bought a Trail Tech CHT gauge but haven't mounted it yet.
I assume the display should be mounted on the headset and the wires run down the tunnel. I need to pull the fuel tank out for another reason but can I get the wire through by just pulling the headlight and speedo or do I need to remove the headset?
The wire is obviously not long enough and an extension is $20 with shipping. I can cut and splice in extra wire or should I suck it up and buy the pre-made one? If splicing is OK should I add to the gauge side of the connector or the sender side?
I did some searching here to see how to use it but anything to do with head temperature or jetting is a deep hole.
The consensus I seem to be getting is that I should gradually drop my main jet size until the temperature goes up then go up a size. 400°F seems to sweet spot.
Am I correct so far?
I have a VDO temp gauge on it now that uses no electricity or batteries but the needle swings around wildly whenever the motor is running. I tried a resistor plug but that helped only a little. It's pretty much unusable while riding. I have killed the motor and looked at it immediately after a hard run and it has never read over 350°. How fast does the motor cool down after a strong pull?
Any advice would be greatly appreciated.
Thanks in advance.
