Vespa px
Vespa px
I've recently been given a horn.
I have a switch, spare battery and wondering how to go about it. Not looking to add to existing wiring. Wanting to keep it independent, thanks.
@jkj-fz6 avatar
@jkj-fz6 avatar
You should use a fuse too.
@shebalba avatar
@shebalba avatar
Is this a decorative novelty horn or just a second internal horn?
Are you looking to amplify the horn by adding a second? If so it might make more sense just to replace the OEM with a higher decibel aftermarket air horn.
@nycsuburbscoot avatar
2024 Liberty 150 S
2024 Liberty 150 S
It sounds like this is a purely standalone situation with a button, battery, and horn.
Vespa px
Vespa px
I'm leaving existing horn as is.
The new one has a special effect sound which I like. So it's really a novelty sounding horn. I would like to keep it independant
@jkj-fz6 avatar
@jkj-fz6 avatar
Wire directly from the positive terminal of the battery, to a fuse, to the switch, to the horn, then back to the negative terminal of the battery.
I would use a momentary contact pushbutton switch.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
How much power does the horn pull? Some horns pull a lot of juice and will overload a momentary switch. You might need to run a larger gauge wire to a relay then connect the horn to the relay. Use a momentary switch to activate the relay. Wiring horns isn't always simple.
Ice cream truck or General Lee?
@shebalba avatar
@shebalba avatar
Ba-na-nah-nah-nah-na-nah-nah-nah-nah-nah!
(It's all there)
@sledge avatar
GTS 300 HPE
@sledge avatar
GTS 300 HPE
@olde_rider avatar
Primavera 150
@olde_rider avatar
Primavera 150
Ooh, that adds so much wind resistance! ROFL emoticon
[ Time: 0.0162s ][ Queries: 4 (0.0087s) ][ live ][ 334 ][ ThingOne ]
