@kahuna1970 avatar
1966 150 Super, 2001 Honda Elite 80, 2003 Honda Ruckus
@kahuna1970 avatar
Can anyone tell me what this stamp represents on the engine? Zoom in on the picture, it's at the very bottom.
Thanks for any help or comments!
⚠️ Last edited by Kahuna1970 on UTC; edited 1 time
@safis avatar
@safis avatar
These are the mating numbers during machining and both should be the same. Yours are two different halves…
@greasy125 avatar
@greasy125 avatar
that stamp indicates the case number (not the engine number or ID) and is used in production to make sure that the two halves are machined together and stay together for proper assembly.
it's not great to have mis-matched case halves, it's not the end of the world either, but there can be problems with mis-matches.
I'm guessing this will be the least of your problems.
let's see the rest of the bike.
@subetherbass avatar
That means your cases are NOT a matched pair, & the rest of the scoot shows signs of Bodginess.
When cases were made they would put the 2 sides together then finish off the round parts for where the crank fits & add the 3digit number... that way the 2 sides were perfectly matched/aligned & therefore crank would sit nicely in place... otherwise there is a chance 1 side is a bees-dick out of alignment and there would always be side load on bearings or worst case, the crank would bind up etc.
BTW; you may want to look at lower rear shock, as that bolt appears to be on a different angle to the mount (ie. bushes knackered & motor is sitting on a lean).
GREEN: bolt appears to be at an angle
RED: hook the end of cable back into loop, as it will be less likely to pull out in an emergency stop situation.
Also, dunno what the spring is for?
BLUE: dem some nasty scratches!
GREEN: bolt appears to be at an angle RED: hook the end of cable back into loop, as it will be less likely to pull out in an emergency stop situation. Also, dunno what the spring is for? BLUE: dem some nasty scratches!
@moto64 avatar
@moto64 avatar
Oh, those wacky Vietnamese.....
[ Time: 0.0139s ][ Queries: 4 (0.0054s) ][ live ][ 329 ][ ThingOne ]
