@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA
@dariusz avatar
Hi, I am asking this question for a friend.
He owns a 2016 Beverly 350 with ABS and need to change the rear brake hose (broken). After that it was a blessing to be able to bleed the air from the brakes, we tried everything we could think of, but nothing worked, we even thought it was necessary to connect a scanner to do it through the ECU, but for that year the scanner indicated it doesn't have that function (it does have it for my 2021 MP3, for a Beverly 2018 too, etc.), could it be that for that year there is a special process to do the bleed?
I have checked the forum but I can't find anything exact and that's why I ask directly.
Thanks in advance for the help.
@dariusz avatar
@dariusz avatar
No idea/options? Crying or Very sad emoticon
The workshop manual (from page 288 onwards) suggests at one point "If necessary, bleeding can be done using a special vacuum pump" and they seem to recommend a Mity-Vac vacuum pump.
https://manuals.wotmeworry.org.uk/Beverley/BV350/
@dariusz avatar
@dariusz avatar
Hi Jimc, thank you, I see it (thanks to the workshop manuals ) let me try find a vacuum pump and test if maybe helps. My concern is the ABS that looks as is adding unnecessary trouble.
@breaknwind avatar
Red Devil SH150i (11,000)
@breaknwind avatar
The motor shouldn't be running or the key on while bleeding brakes. There's a hump in the rear brake line that can cause problems. One member posted about removing the caliper, installing a spacer and bleeding it above the hump.
@dariusz avatar
@dariusz avatar
Thank you, any options are welcome
@jk_single avatar
Vespa P200E, Fly 50, Vespa S50, Vespa GTS 300
@jk_single avatar
I have seen videos on youtube when the guy repairing car brakes hasn´t had the possibility to use a "scanner" for activating the abs pump, and would drive on a gravel road and stab the brakes to activate the abs. This might force the air out of the pump. I guess the brakes were "semi-bled" before this.
This might work with the rear wheel, on a scooter...
[ Time: 0.0124s ][ Queries: 3 (0.0053s) ][ live ][ 334 ][ ThingOne ]
