You'd probably get a better response on the FB C3 page. Speed sensor usually flashes when the scooter has been revved without the front wheel spinning. Put a piece of 1/4 fuel line on the injector. Fill it with carb clean or fuel, re-hook to the power supply. Blow into the hose with your mouth. Do you see a spray now? Soak the injector overnight, and brush it clean with an old toothbrush. The OE Yamaha injector is pretty robust and usually lasts the life of the scooter.
