ET4 150
ET4 150
Hi
ET4 150 sitting around for about 6 months. I changed the battery and charged it. Installed battery and tried to start no power at all to headlight, turning lights or horn. I do have red blinking light on speedometer.
Any suggestions what I should look for before I start taking it apart?
Greg
Check the fuses - one goes to the immobiliser and onto the CDI which powers the LED. The other (likely to be blown or a bad connection) does the other stuff, including dash lights.
ET4 150
ET4 150
I'll check as soon as I get home this afternoon
Greg
ET4 150
ET4 150
Hi
I changed all of the fuses 2 near the battery and 2 on the left front panel
Still no power to light up anything
I know the battery is good. But no luck
Any help would be greatly appreciated
Greg
Check the ignition switch....my best guess at this point. Facepalm emoticon
ET4 150
ET4 150
Greg
ET4 150
ET4 150
Thanks. That was it I needed a new ignition switch
Started right up after I installed it
One more question I have
It idles a little rough and when I try to accelerate the engine dies.
Any ideas?
Thanks again
Gref
Any ideas?
Thanks again
Gref
The carburettor needs a thorough clean, and the vacuum and fuel lines need to be checked for cracks. Changing them is a very good idea after all these years.
ET4 150
ET4 150
Thanks again
You're the best
Greg
[ Time: 0.0091s ][ Queries: 3 (0.0024s) ][ live ][ 334 ][ ThingOne ]
