So I ended up buying a neat little Px200e. Seems it has been discussed 16 years ago. It has a few flaws but the body is straight and poking around a bit it also has quite a few nice aspects to it.
Things that are neat:
Malossi 210
Spaco 26 26
Appears to be a SIP box exhaust
Ducati flywheel which indicates, what exactly? I don't know.
Bad issues: tail light that only worked when running suddenly now doesn't work at all. Brake light never worked.
Lower part of cases covered in oil and black gunk. Seems to have a leaking seal is my guess. Rear brake also just suggests it works. No real stopping power. Again, suspected rear seal leak oiling the brakes.
Right turn signal works, left doesn't. Indicator light on headset flashes as normal when switch turned to right, very dim and flashing quickly when switch turned to left.
Headlight only works in one position, either hi or low. No idea since all markings on the switches are rubbed off years ago.
She runs, but obviously very rich. Jets are the little one is a 55-160 and the larger one to the right is a 190. Pulled them and cleaned them using gas and blowing them out using carb spray. Ran a little better but I noticed fuel spraying out of the 190. Is that normal? No clue. Doesn't want to idle. Adjusting screw at the rear is screwed all the way in.
Last thing is I bought it in Newport Beach and live in the mountains at roughly 4600 feet. I know the altitude is part of the issue.
Help!
