Hi all, I crashed my 2007 250 the other day and it slid engine first into a curb resulting in a cracked engine case.
Maybe it can be welded I've seen it done in the past, a good welder can weld cast aluminum, oil pan is easily replaced if it's cracked.
Posts: 428 Location: Dahlonega, GA |
daniel981 wrote: Hi all, I crashed my 2007 250 the other day and it slid engine first into a curb resulting in a cracked engine case. ![]() |
The right guy could TIG weld (Heliarc) that in place. Of course, you would have to get the oil pan out of the way. And find the right guy. But it may be a lot easier than replacing a whole engine.
2024 Vespa GTS 300 Super Sport, 1980 Vespa P200E,2014 BMW C650GT
Posts: 72 Location: Sulphur Springs IN. |
Picked up a low mile 300 engine for my 250 on Facebook market place for ~$600...GL getting it back on the road.
Positive
Thank you all for the leads. I will check out the sites mentioned, and I may even take the advice to pull it apart and weld it up to get it back on the road. Thanks for the ideas!
Hey Daniel...bummer. Sorry to here that. I have an 2007 GTS engine, but it is attached to the rest of the scooter.
If you're interested in a whole new rig, hit me up. I'm in SoCal as well. |
Thank you, I decided to just part it out... It's gonna be much more expensive to fix than what the thing is worth at this point. I'm bummed, but thankfully we have two other Vespa's we can ride still.
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 45180 Location: Pleasant Hill, CA |
daniel981 wrote: Thank you, I decided to just part it out... It's gonna be much more expensive to fix than what the thing is worth at this point. I'm bummed, but thankfully we have two other Vespa's we can ride still. ⚠️ Last edited by jimc on UTC; edited 1 time
Unfortunately it's more than just the cover that's damaged. The case inside the cover is also pushed in and broke the post for one of the bolts.
I tried replacing my 250 with a 300 engine but the wiring loom is different so I managed to get a 250 engine from sloten recovery .
