Modern
Modern
Hi - the airbox cover screws have been 'enthusiastically' screwed in previously and stripped the plastic out of the airbox mating 'tubes'. They are waggling about and wont screw down snug. Any suggestions on how to fix this or do I need a new airbox?
Ta
@der_blechfahrer avatar
Try glue. Put in the screws a half milimeter short and let the glue set. Then turn them loose to break the thread then tighten them up.
If it doesn't hold, clean it and try another type of glue. I think I'd try superglue first. Maybe add some baking soda as filler.
@carlito avatar
Yourban
@carlito avatar
Yourban
Insert een black tie wrap in the screw hole far as possible and screw. Cuttoff the insert head of the tie wrap.
Ta
@safis avatar
@safis avatar
Get some thicker screws Piaggio uses on other plastic covers. They do the job...
https://www.sip-scootershop.com/en/product/covering-screw-4x19-mm_PI267958
You can also try a hardware store. You need 4x19mm or 4x20mm (8x3/4) round head wood screws...
@fudmucker avatar
@fudmucker avatar
If you soak the cable tie in acetone for an hour or so before inserting, it will soften and bond better with the casing...
Vespa ET2, LX50 2T
Vespa ET2, LX50 2T
Quick search on eBay and there is a used one on there for £25 posted.
[ Time: 0.0105s ][ Queries: 3 (0.0014s) ][ live ][ 334 ][ ThingOne ]
