@carlito avatar
Yourban
@carlito avatar
Yourban
Hallo
I have a 2014 Yourban 300cc sport.
Currently I am only using Malossi Delta Clutch and a Malossi multivar. Installed the white spring and 16gr rollers.
Intend to use the Malossi kevlar CVT-belt.
Anyone with this setup here had an oil leak at the crank case?
I used the variator with 17gr DR Pulley (Slider/Roller), it seems that the belt hit the crank case and possibly the oil sump gasket and there is some oil leak in the crank case.
⚠️ Last edited by Carlito on UTC; edited 1 time
common issues, replace the gasket and use a razor blade to shave the excess gasket sticking up.
@carlito avatar
Yourban
@carlito avatar
Yourban
Thans for your reply. But tonyour knowledge, wil the Malossi CVT-belt with Malossi 16 gr rollers hit the crank case?
[ Time: 0.0095s ][ Queries: 3 (0.0024s) ][ live ][ 329 ][ ThingOne ]
