Been reading up on evaporative canister removal and general poor running problems, as my GTS threw a code (flashing engine) a couple of weeks ago (was running rough). So, after having local Cespa dealer evaluate rather than remove the evap system I simply plugged the nipple at the engine and towards the tank I added 2.4 feet of line to allow overflow down towards the ground. Note that the line that was originally connected to the tank (between the tank and the first valve in the evap system) had fuel running out of it (only about 1/4 of the tank was full)!
Anyway, after taking the rear tire off (getting new tire after big flat) I started thinking about heat and the location of the fuel tank. So, it's directly above the muffler, right anbove the water pump, and right next to the engine. I wonder if those that have been having problems with stalling and rough running in the heat have considered this?
I wrapped the front of the muffler with heat wrap and then I put a high heat reflective, sticker backed material between the tank and muffler and between the engine and fuel tank.
My understanding is that hot gas is not conducive to good running. Anyone else had experience with this? I'll be out riding in 90 degree (F) heat over the next couple of days and let you know what I discover.
