Hi,
As i am soon going to have the engine out to swap my exhaust i though id ask for advice on this as i'll probably pull the engine to do it.
I had an intake leak when i first got the PK but i thought i fixed it already. There were one and three quarters of an intake gasket so i removed them and put in a new one i cut and this problem seemed to dissapear.
The problem shows itself in two ways:
I just ride along like normal, and when letting go of the gas it will just keep going like some sort of weird cruise controll. This can keep going for quite a while, usiually falls out of this behaviour with an increase in load like applying the breaks or a hill.
The other way is that i will ride around like normal, i come to a stop, plopp it in neutral like normal and it just starts revving to the moon without me touching the gas. Seems more common when on an incline. I have never let it just go off until it sorts itself, always stop it with the clutch and breaks.
I had both of these happen today and it is quite unplessant when in stop and start trafic and the Vespa want to hug the car in front of you unexpectedly.
The thing i dont really understand is why it only happens from time to time. Today it was almost omnipressant on my commute but yesterday it didnt happen at all. Only difference i can think off were that i gassed up this morning and that the outside temp is 2c warmer today.
Engine is stock besides slightly richer jets.
Any clues where to look next? I will inspect the intake gasket again but other than that i am lost. I have checked that the cable and slide are free and return even when pushing on the slide or doing other dumb stuff to make it bind.
