I know this subject has been beat to death. I searched the forum for examples of this fairly common machine and equipment mod.
In the case of the GTS front end wobble it might help/improve the characteristic wobble and lack of dampening at the steering head .
In other machines and equipment utilizing enclosed shafts for slow speed applications the addition of grease to the shaft housing greatly dampens the transmission of minor vibrations.
A similar example is automotive split driveshafts, steering columns at the telescopic spline (my Toyota Sienna) and hand controls on machine shop equipment.
I thought I might try adding a remote grease fitting to the steering shaft housing on my GTS. I have no problem removing plastics to access the area of the steering head and adding a grease fitting. It could be extended to be accessed in the glove box or behind the front horn cover
Heavier non synthetic wheel bearing grease could be pumped in till it reaches both bearings.
Head bearings should be at proper torque, weighted bar ends, quality front tire, good front shock setup, etc.
I will probably drill a 1/16" hole at the head tube with a slight countersink and use a needle tip on my grease gun.
Just throwing this out there. Maybe it's an idea that will help???
Comments....... Go easy on me; I'm usually not a hack but I'll try anything that might work in this case.
