mp3 500 2008
mp3 500 2008
The bleed valve on my 2008 500 is stuck closed and all my attempts to loosen it have just resulted in a melted nut. I know there is air system that is preventing circulation and the engine is not getting coolant. The is pressure in the system so the pump working.
The only thing I can think of is to do a vacuum bleed. Any one tried this? I find a kit on line that does not use an air line, but can find anymore info on using on a motorcycle.
[/i]
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
only way is drill it out and replace so head off repair
Or get an other head but those are expensive
Piaggio MP3 400
Piaggio MP3 400
you can blade the air by opening the higher pipe instant the bleed hose
it is less convenient but it is only for once
mp3 500 2008
mp3 500 2008
Which pipe do you mean? On the coolant pump there are three, do you mean the smaller one on the inside?
Piaggio MP3 400
Piaggio MP3 400
The one that connected to the thermostat ...
open the band till fluid get out than closed it
Almost same as you do with the bledder
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
will not bleed the head
Piaggio MP3 400
Piaggio MP3 400
why not ?!
the blader and the pipe are taking air from same place/room.
2015 MP3 500 ie Business
Why not just get a new t-stat housing?
mp3 500 2008
mp3 500 2008
the bleed valve is in the head not the stat housing.
I tried the vacuum refill and it seemed to work, but when I started the bike the seals on the reservoir started leaking like mad. They are 16 years old and made for pressure not vacuum.
I got the bike for $2K 6 years ago as a summer commuting bike, so I've got my money out of it. I have donated it to a charity that will take it from me as is and auction it off or sell for scrap.
Now I need to find the money for a 2024 530 Exclusive
[ Time: 0.0125s ][ Queries: 4 (0.0034s) ][ live ][ 331 ][ ThingOne ]
