@paluss avatar
GTS300
@paluss avatar
GTS300
Decide to replace the ABS tone wheel on my 2022 GTS 300. No problems in the mechanical part (there is Loctite on the bolts so a heat gun is necessary). So I decided to take it out for a ride. Tried to reset the ASR, while I was riding I noticed the speedometer was not working and the ABS light was lit and the check engine light came on. After a few miles the Speedometer needle moved and is working, but the ABS and check engine light are on.
Searching through the threads cant find anything so far, I was thinking of disconnecting the battery.
All help is welcome, thanks!!!!!
Vespa GTS 300
Vespa GTS 300
Distance between tone wheel and sensor too large? The workshop manual states 0.5 to 1.5 mm.
⚠️ Last edited by GermanGTSDriver on UTC; edited 2 times
@paluss avatar
GTS300
@paluss avatar
GTS300
thanks will check
2019 GTS 300 HPE SuperTech 71,000km
further to what GermanGTSDriver said:
Mine has two washers, one each side of the plastic bit of the sensor. very small and easy to loose.
Once it's working ok then a few cycles of on-ride-off will cause it to clear itself.
@paluss avatar
GTS300
@paluss avatar
GTS300
looking at the gap, it appears to be a 1/4 of an inch or more Facepalm emoticon All done for today, I will take things apart in the morning. "no good deed goes unpunished" ROFL emoticon
@srd0060 avatar
2022 Super tech/ 91 PX 200e/97 PX 200e
@srd0060 avatar
Hi, yes that gap is so important and as you found out if it outside the tolerance its no good.
@paluss avatar
GTS300
@paluss avatar
GTS300
thank you Sir
@paluss avatar
GTS300
@paluss avatar
GTS300
hey guys thanks again, I put the spacer on the wrong side. everything seems to be working fine now (CEL is still on, but it normally will clear after certain amount of starts/cycles), now time to test the accuracy and any speed increase Laughing emoticon
@paluss avatar
GTS300
@paluss avatar
GTS300
So, test ride of about 20 miles went fine, Speedo is now matches GPS, as far as extra speed, on a long safe stretch of road I was able to peg 80 MPH with no limiter kicking-in, perhaps on a slight down hill it would go faster.
Other than that test ride I mostly cruise at 65 to 70 mph (but nice to know it can go faster).
Also, the CEL light went out, so everything is back to normal. Best part is I learned a lot about my scooter
Vespa GTS 300
Vespa GTS 300
Thanks for your feedback!
[ Time: 0.0177s ][ Queries: 5 (0.0081s) ][ live ][ 334 ][ ThingOne ]
