Not so happy
2000km, no real abuse.
![]() UTC
Posts: 7411 Location: Batmania aka Melbourne, Aus |
![]() 2019 GTS 300 HPE SuperTech 73,000km
![]() S50, R1100s, way too many pushbikes
Posts: 11027 Location: Hermit Kingdom |
![]() UTC
![]() UTC
znomit wrote: I call BS River crossing on a GTS - how deep? I'm sorta suspecting heat ... |
![]() UTC
znomit wrote: Where did all the bits that aren't attached to the rollers end up? Just looking at the previous rollers with 5000km they have a minor amount of this but nothing like that big missing chip that appears to be all the way through the metal to the plastic. Thinking I'll put those in for now |
Counterfeit parts , that have got into the supply chain ? When I had my classic bikes I was shocked at the notoriety of fake NGK sparkplugs!!!
![]() UTC
znomit wrote: You buying these from aliexpress? (Piaggio Australia does the imports as some sorta partnership with Peter Stevens Importers and i buy direct from them). |
![]() UTC
SteelBytes wrote: And before someone asks about orientation: i install the way Robot says "clockwise open"
Positive
![]() UTC
znomit wrote: There's your problem, you're in the southern hemisphere! |
SteelBytes wrote: Ah, so should i also put the belt on in the opposite direction? |
![]() Polaris Grey Rally 200, Blue Marine Primavera ET3, Coral Red 50 Special
Posts: 469 Location: Melbourne |
![]() UTC
SteelBytes wrote: I'm sorta suspecting heat ... |
![]() UTC
Posts: 12550 Location: Fond du Lac, Wisconsin |
![]() 2015 GTS 2017 BV 350
SteelBytes wrote: Ah, so should i also put the belt on in the opposite direction? You'll be fine. ![]()
Positive
![]() UTC
JakeM wrote: If the previous ones have coped fine with the heat, I'd be more tempted to think that there's been a bad batch? Bad casting etc but has no one else seen this? |
