Hey everyone, before i go and replace the fuel pump does the 22 GTS HPE have a fuel pump relay and if so where is it?
Yes!
The relays (except for the starter relay) are located under the cascade. "Remote relay injection charging: 30 (white/black) input Power supply via battery 85 (black/purple) Signal input (-) for coil of MIUG4 control unit 86 (red/white) Power supply input via ignition lock ignition lock 87 (black/green) Power supply output from contact for injection charges" https://manuals.wotmeworry.org.uk/Vespa/GTS%20300i%20HPE/GTS300%20HPE%20E4%20Workshop%201Q000725%20%5Bde%5D.pdf (Workshop manual for 2022 HPE only available in German on wotmeworry. Hope it works for you?!) SKU: 1D0016360 https://www.sip-scootershop.com/en/product/relays-piaggio-12v-30-10a_PI016360 Identical to "Elektrolüfter-Fernrelais" (= fan remote relay) & "Licht-Fernrelais" (light remote relay) Please describe your error symptoms. ![]() (Page 161) "Fernrelais Einspritz-Ladung"
![]() (Page 115)
![]() (Page 121) No. 18 = Remote relay injection charge / No. 25 = Ignition coil / No. 26 = Injector / No. 28 = Fuel pump / No. 30 = Injection control electronics
![]() UTC
2019 GTS 300 HPE SuperTech 71,000km
Posts: 7146 Location: Batmania aka Melbourne, Aus |
![]() 2019 GTS 300 HPE SuperTech 71,000km
I have to ask why? do you know that there was a fuel pump issue with a recall? have you asked your dealer if the vin of your scoot is affected? Or some other issue?
SteelBytes wrote: I have to ask why? do you know that there was a fuel pump issue with a recall? have you asked your dealer if the vin of your scoot is affected? Or some other issue? |
![]() UTC
srd0060 wrote: Hi, my scooter doesn't come up on the recall. PSimporters/Vespa Australia don't seem to want to come to the party srd0060 wrote: The pump doesn't prime when hot known fact, the importer/vespa Australia wants flow test and pressure tests done by the dealer which is a time consuming process and the scooter needs to be hot. |
srd0060 wrote: Hi, my scooter doesn't come up on the recall. srd0060 wrote: The pump doesn't prime when hot known fact As far as I can see, the three relays behind the cascade are identical, if this is the case, then you can try reconnecting/replacing them. |
![]() UTC
Not the nicest looking relay. It's that cracking i see?
where do you live? For a youngish scoot that doesn't look so good. I live in Melbourne with my 2019 parked on a North facing porch, but not near the water. |
Hey mate, Townsville at the moment i was in canberra up until Jan now here. i have replaced the relay so tomorrow is the test not holding my breath.
To answer f few post way back, i checked myself PSImporters need it to go to a vespa dealer to have fuel flow tests and various others test run and I dont have time for that. PSImporters refused to help or check for recalls. I a $60 ebay pump has fixed the issue. I have emailed the warranty people with no reply....says a lot for the customer.
