Vespa GTS300 (2012)
Vespa GTS300 (2012)
With the bike off the centre stand & stood on it's 3 wheels with the tilt lock & parking brake on,would an MP3(500) be stable enough for a passenger to get on the bike before the rider & get off after the rider?.
Thanks, Graham.
Yes - I gave a lift to a (large!) friend back from the pub many times on my Fuoco. Just the tilt-lock and parking brake.
2016 Mp3 500ie Sport
Echoing JIMC: yes it can be done.
But the MP3 is already a bit top-heavy and it doesn't take much to topple over, especially if the surface its on isn't perfectly level.
I would recommend being with them to help hold the bike steady while the board or even stand in the step-through to brace the bike. Most of the time its probably fine if you do not do these things but that's a long fall onto a hard surface the one time it does not go to plan.
Think risk reduction measures not just for yourself but passenger and machine alike. As the motorcycle owner and driver you also have the responsibility to ensure your passenger is safe boarding, riding, and dismounting the motorcycle.
Vespa GTS300 (2012)
Vespa GTS300 (2012)
Thanks jimc, am i reading your reply correctly, you are off the bike while your passenger gets on ?.
Vespa GTS300 (2012)
Vespa GTS300 (2012)
Thanks, yes should have said, i would of course(as the rider)be holding the bars & have my weight against the bike for extra stability.
Thanks for both replies, i couldn't figure out how to "multi quote".
Yes. First, he's a seasoned motorcycle rider himself, and second, it takes a huge heave-ho to topple an MP3 on the tilt-lock.
That's easy! Quote the first one, select all and copy, then dismiss that and quote the second. Paste the first above the second, add comments where you will.
Vespa GTS300 (2012)
Vespa GTS300 (2012)
You mean like this ? , Thanks again.
Thanks, it looks like an MP3 could be the answer to keep us riding in the US.
MP3 500 HPE 2019
MP3 500 HPE 2019
No problem at all, wife is on and off in a shot, and she certainly jumps right back into the passenger seat, no holds barred. Facepalm emoticon
Vespa GTS300 (2012)
Vespa GTS300 (2012)
Thanks for replying, i don't think my wife's quite so agile nowadays , but it sounds like she should be able to make it to the rear seat with the tilt lock on, i think i'm going to start another thread, with my reasons for the sudden interest in an MP3.
Thanks for all the replies Graham .
[ Time: 0.0117s ][ Queries: 3 (0.0057s) ][ live ][ 334 ][ ThingOne ]
