Vespa Primavera 125
Vespa Primavera 125
Hi,
I was trying to adjust my left hand rear brake with a ratchet and pliers and it's snapped off. I have no idea what to do, can someone help me please
Vespa ET2, LX50 2T
Vespa ET2, LX50 2T
I think you are going to need a complete new brake cable as it all comes as one piece.
The cable itself isn't expensive (ยฃ20-30).
Video below (not the exact scooter you have but it will be very similar).
?feature=shared
Vespa Primavera 125
Vespa Primavera 125
Thank you. I've neglected it a bit and not really looked after it as I should. Never had a Vespa before and my mechanical skills are non existent.
It's rusted from weather etc so not sure if I should just cut my losses with it lol
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
I'm sure you could bodge something together to make it work.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
One place it's best not to bodge something together is brakes. They're kind of important. By all means, bodge it to get home. But long term, replace the brake cable.
@grunion avatar
150LX
@grunion avatar
150LX
Is it just me or is that tire mounted backwards?
Just you
Vespa Primavera 125
Vespa Primavera 125
I hope not as it's a right knob to remove. I had a puncture
@buggsy avatar
@buggsy avatar
Yeah, don't bodge, something you depend on that makes you stop and while you are at it flip your back tire its on backwards.๐Ÿ˜‰๐Ÿ‘
Vespa Primavera 125
Vespa Primavera 125
Oh dear ๐Ÿ™ˆ. Does it make much of a difference?
Apparently two people in this thread have tyres mounted backwards, and neither of them is you.
@grahamlml avatar
Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
@grahamlml avatar
Llywellyn I know you are a Cardi with short arms and deep pockets just buy a new cable.
You still the other side the river from me can sort it or did you move?
Vespa Primavera 125
Vespa Primavera 125
It's on order mate. No I'm south now, I'm between Swansea and Bridgend.
Vespa Primavera 125
Vespa Primavera 125
It's all good ordering but I've no idea what I'm doing even after watching videos ๐Ÿ˜†
@grahamlml avatar
@grahamlml avatar
Dai at In Small Wheels maybe a place to take it, he hรกs a good rep.
Think he's in104 Clyndu St, Morriston, Swansea SA6 7BG
Website
https://onsmallwheels.co.uk/
@buggsy avatar
@buggsy avatar
The rotation arrow is there for a reason, mainly water displacement in wet weather.
Vespa ET2, LX50 2T
Vespa ET2, LX50 2T
Indeed but they are fitted right. The tyre has 2 direction arrows depending on if they are fitted on the front or rear. The tyre in the picture is the rear.
@buggsy avatar
@buggsy avatar
well spotted didn't notice the right arrow.๐Ÿ˜‰๐Ÿ‘
@buggsy avatar
@buggsy avatar
And not me, didn't spot the ar to the right, two directional tread. ๐Ÿ˜‰๐Ÿ‘
@grunion avatar
150LX
@grunion avatar
150LX
I confess, I was wrong. A temporary lapse of reason but I am contrite, I'll even have a larger helping of broccoli tonight in self-flagellation.
With all that rust it might make sense to look at the entire brake back there and when did you last change the front fluid? The front caliber is vulnerable for seizing on old brake fluid (it corrodes the piston bore) but I suppose "like the idiot clock that strikes 13, all previous judgements are suspect."
And two people in this thread have hauled on the wrong nut too hard without loosening the other one first, with the same result.
Vespa Primavera 125
Vespa Primavera 125
I have ordered a new brake cable, just got to find out how to fit it now ๐Ÿ˜†
Vespa Primavera 125
Vespa Primavera 125
Please say this in English. Have I put my wheel on backwards?
The tire is currently correct.
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
No, he's saying the original part broke because you (and many other people) tightened the retaining nut ("keeper nut") without understanding that the OTHER threaded part the nut touches is for adjusting the brakes. You are supposed to loosen the retaining nut first, make the adjustment, and then tighten the retaining nut to hold the adjustment in place. It isn't complicated, but it isn't obvious. You'll see with the new part.
Vespa ET2, LX50 2T
Vespa ET2, LX50 2T
For future reference
Just replaced the brake cable on my LX, a primavera a going to be similar I would think.
First the horn cover comes off, then the mirrors and headlight cowl.
Then the inner leg shield cover then the spark plug access panel and floor panel. In the LX the 2 rear plastic side panels are attached to the floor so they come off also.
It wouldn't just thread through without taking all that off.
Little holder on variator cover I took off also.
I also replaced the lever and mount (as the thread for the mirror had stripped) so that's why the grip and lever are missing.
It's pretty straight forward just a lot of things to take off.
[ Time: 0.0166s ][ Queries: 4 (0.0039s) ][ live ][ 334 ][ ThingOne ]
