Hey guys, I was replacing the throttle cable on my ET2 and the bolt broke. What can I do it get it out??
Posts: 46110 Location: Pleasant Hill, CA |
Cut the old cable, and use a bolt extractor.
https://www.harborfreight.com/screw-extractor-and-left-hand-drill-bit-combo-set-10-piece-63987.html |
Ok sounds good, after I cut the cable can I use a spare throttle cable I have that goes from the junction box to the carburetor on this or do I need a specific cable?
Newride wrote: Ok sounds good, after I cut the cable can I use a spare throttle cable I have that goes from the junction box to the carburetor on this or do I need a specific cable? |
Well I was replacing the cable from the junction box to the carburetor because i went from the 12mm carburetor to the 17.5 and the forums said I needed a new cable. I dont what this second cable goes to (its my first moped) but I took it out to release tension. I accidentally got a second cable that goes from the junction box to the carburetor, would that work for whatever this one goes to? It's a et2
Posts: 23388 Location: Harriman, Tennessee, Tn |
from what the condition of the outer cable looks like you need a complete new cable anyway, just order the proper cables.
Posts: 3725 Location: Babcock Ranch, Florida |
Newride wrote: Well I was replacing the cable from the junction box to the carburetor because i went from the 12mm carburetor to the 17.5 and the forums said I needed a new cable. I dont what this second cable goes to (its my first moped) but I took it out to release tension. I accidentally got a second cable that goes from the junction box to the carburetor, would that work for whatever this one goes to? It's a et2 |
old as dirt wrote: from what the condition of the outer cable looks like you need a complete new cable anyway, just order the proper cables.
Posts: 2004 Location: Tucson, AZ |
Newride wrote: I dont what this second cable goes to (its my first moped) but I took it out to release tension. I accidentally got a second cable that goes from the junction box to the carburetor, would that work for whatever this one goes to? It's a et2 |
az_slynch wrote: The cable in question adjusts volume for the autolube pump. It's located under that side cover and behind the front CVT pulley. If you go in to replace the cable, I recommend getting a new drove belt for the autolube pump too. https://scooterpartsco.com/210-vespa-c-801_802/throttle-cable-from-junction-box-to-oil-pump-for-vespa-et2-562408-p-36869.html And this? https://scooterpartsco.com/300-piaggio-c-801_836/piaggio-belt-for-vespa-et2-p-36264.html |
S150 '09, Beo 500ie '08
Posts: 1576 Location: Bermuda |
jimc wrote: Cut the old cable, and use a bolt extractor. https://www.harborfreight.com/screw-extractor-and-left-hand-drill-bit-combo-set-10-piece-63987.html The trick…technique, actually…with EZ outs is to drill the broken bolt as much as possible, ideally using an reverse bit, and use the largest EZ out possible to extract the resulting bolt shell. If you break off a a hard, brittle EZ out bit in the broken bolt you just created another even more frustrating problem. |
Posts: 1952 Location: Berlin |
I concur. Take off the variator cover and you can reach the broken bit from behind. It's probably enough to jam a screwdriver into it.
Here's a picture from an LX50 2t, which is probably the same.
Sounds good, I order all the parts. Except for the screw. What is the screw/bolt that I broke called?
