It was clear the front wheel was bent. Riding it had a huge wobble and spinning it in the air when mounted on the hub it had about 10mm of runout at the rim. It had impact damage clearly, looks like it probably hit a curb real hard. Scooter's been down sometime long ago with bent bodywork on the same side as the curb impact. So I bought a new front wheel and had the tire switched over.
Now it still has a little bit of runout and the rotor scrapes when you spin it. I took apart the spindle and bearings, repacked everything, reset it. Still has a little bit of runout.
Is it likely the hub is bent? Part #50 in the diagram. Can that part be straightened? Or would you trust a used part? New one is kind of expensive.
If it's not the hub, maybe part #2 in this diagram may be bent:
SW shows out of stock for the part. Is this a thing? Seems like if it was bent it wouldn't cause the wheel to have a wobble/runout in it, but it'd run straight, just not square with the fork.
Thx-
