nealf2002 wrote:
I just acquired a 1958 Allstate with a replacement engine, supposedly an LML. How do i find the serial number to positively identify the engine? Pls ignore the bogus kicker. I have to figure out the right replacement. ...
Motor appears to be LML w/ the distinctive hump in the fan cover unique to LMLs, but the cylinder cover may be from an older Vespa - all those I've ever seen are plastic like newer Vespas.
Your motor serial number should be stamped on the swingarm just behind main pivot bolt, same place as on Vespas.
I assume you are looking for older style curved kickstart lever to match your older frame? You'll need this special one with the splines offset to match your newer motor.
https://www.sip-scootershop.com/en/product/kickstart-lever-sip-vbb-style_751222PO?usrc=kickstart%20lever%20px
So is the motor converted to 8" wheels, or are you 10" in back & 8" in front? I also have a '58 AllState with a Bajaj motor now in it converted from 10" to 8". Also a 125Super w/ LML 10" motor which I converted the front to 10". I like front & back to be the same size!
Love that paint, just prep & rattlecan the cowls the closest blue you can find. Done!
