180ss
180ss
Hi everyone, was just wondering, when closing up engine cases, have any of you added "gasket sealer" to the new engine gasket (and other gaskets)? If so, which one (brand) have you used? Is it a good idea to use sealers?
Fab
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
The service manual says "spread seal paste on both surfaces of the gasket".
Everyone has their favorite. I use MotoSeal.
@chandlerman avatar
Innovator
61 Days Since Last Explosion
Innovator
@chandlerman avatar
That's putting it mildly.
I use Permaseal aviation-grade gasket sealer. Others swear by hondabond/threebond/yamabond. Others use RTV silicone. Still others insist that if grease was good enough for the OG, it's good enough for you.
VNB VSC VMA VSX - o9c vmb vse
Hylomar spray.
I am a convert from the days of grease before converting to permetex and then the one true gospel of hylomar (and the angels did sing).
Find said religion here:
https://shorturl.at/31FXd
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
always
@mor avatar
1974 v90, 1959 Allstate, 1979 p200
@mor avatar
Hylomar spray.
Is that like the copper spray, but for paper instead of metal?
180ss
180ss
Hi gang, thanks for the replies. I was looking around and read that good, old grease does the job too? I didn't even consider grease. I have some high-temp moble1 grease...would that work well? I just don't want to put anything really sticky that will make it tough if i need to reopen the cases.
Fab
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I mentioned plain ol' grease! Razz emoticon
Yes, you could use it and it can work. What you'll ultimately find is that the more modern solutions are more likely to work correctly over the long-term.
The Permatex aviation gasket cement is the least sticky, while still working. You can generally get the gasket back off pretty easily, then clean up the sealer with acetone.
mor_ wrote:
RE:Hylomar
Pretty much yes... I think copper spray may be rated for higher temps but Hylomar goes up to 425+ IIRC
It's just so easy to spray the gasket surfaces and the mild drying times gives you a zero worry window to get it on the cases and the cases closed.
None of the options listed will make it harder to reopen the cases, albeit some of the more sticky ones will ruin your gaskets if you have to reopen the cases.
But... that is a small price to pay for piece of mind.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
In the case(s) of hondabond/yamabond/threebond, I beg to differ, but other than that, yes.
@mjrally avatar
73 & 74 Rally, 76 ET3, 80 P200, 61 Ser 2, 65 Silver Special,, 2015 HD Road Glide Special
@mjrally avatar
I like motoseal, but here's a little trick I've developed. Put it only on the lower half of the case gasket and selector box but all of the cylinder base gasket! That way when parked, there's no drips and you don't have to worry about air leaks.
Fair... I have exp with the three I mentioned: grease, permatex, and hylomar. (Case separator always wins.)
@hibbert avatar
Vespa
@hibbert avatar
Vespa
Birdsnest wrote:
Hylomar spray.
Yikes that's pricey must be good.
@oopsclunkthud avatar
3:5
never used the spray but have been using Hylomar from a tube or can since the 80s.
nice thing is if you need to split the case you can often do it without destroying the old gasket. Nice for road side work.
What ever you have lying around. .... Honestly, I use Motoseal because I bought a fairly large tube of it 15 years ago and still have half of it left.
@poidog avatar
Drama Free
79p200e 66smallstate 85pk50xl 84p125ets 63GL
Drama Free
@poidog avatar
+1 to both of the below statements.
Beauty about the spray is that whatever isn't used at that sitting, stays good in the can. Sort of like spray paint vs. a can of paint. Plus the spray gives a nice, even, light coat, without having to muck around smearing it with your finger, or some other appendage, or some kind of tool.
Birdsnest wrote:
Hylomar spray.
[ Time: 0.0095s ][ Queries: 3 (0.0030s) ][ live ][ 334 ][ ThingOne ]
