Howdy. Still sorting thru things on my recent up-from-the-junkyard V100 build.
I thought I finally had the shifting and transmission in order. Everything has been fine as I drive around my quiet local streets, which are flat. It's a 3-speed.
Then, today, I took it on a longer ride over a hill, and, while going uphill, the bike either popped out of 3rd gear or the clutch lost all grip. The effect what that I was happily tooling along, and then—pop!—the engine was just spinning, as tho I were in neutral.
When it happened the second time, I gave up and continued the short trip in 2nd gear. No problems.
When it slipped, I MIGHT have been lugging the engine a bit. I'm new to this and might have been shifting too early.
My thought was that maybe the clutch was slipping—that it isn't adjusted correctly and it gave way. Although there's free play in the lever.
I've had no problems in first or second, and no problems in 3rd when I'm on level ground. This happened in 3rd, only going uphill, and maybe at relatively low RPM. I might have been accelerating as well.
Thoughts? I'm a noob and trying to think this through, but I'm finding that my first guess about Vespas isn't always right . . .
Muchas gracias
