I've converted both my VNA Allstate and VB1 Wideframe both over to 10" wheels by using a PK fork in the VNA, and a PX fork in the VB1. I also swapped in a PX fork in my pink PK200 project. The PX fork is less than optimal choice unless you do a fair about of work.
The main problem with using a PX fork is that the upper shock mount bracket is HUGE when compared to the PK. Which means when you turn the handlebars to the left, then the upper shock mount bracket will make contact with the legshield (right below the horn cast). You would have to bottom steering bearing race would need to be about 3/4" lower to get the needed steering clearance.
The other problem that's easier to remedy is creating the space for the front shock. Which means you'll need to show off your (fender) bulge skills by creating the said required space.
By now the fork will be fairly tall, so you'll have to cut and lower it to make it match the rear swingarm height. Cutting and welding a fork is super easy. Aligning it so that it's perfect before the welding IS super challenging.
I doubt if i will try to modify a PX fork again to make it fit an older vespa. The PK is so much easier, but it still requires a ton of work. For the next hydro discount brake conversion that i do, i'll keep the original vintage fork and use an off the shelf plug n play disc brake kit.
Link and pics to my rusty VB1 project. Somewhere there's pics of the fork and fender mods.
1958 VB1 200 Wideframe scuttle bucket
Link and pics to my Allstate VNA project. And somewhere in there are also pics of the fork and fender mods.
Project 61 Allstate 200 (now 208) with 2020 updates
