2008 PIAGGIO MP3 400
So I can program my trunk release keyfob, and it'll work a few times, but then stop working.
From what I understand, there's a radio inside the MP3 that detects the button press, and then triggers the trunk release.
The keyfob's light shows green when I press the button, and I already replaced the batteries, so I am 99 percent sure it's not a keyfob battery problem.
Is this a relatively widespread problem, or something more unique?
I can get into the trunk, that's not the problem. The issue is I want the buttons on the keyfob to work, not do the key insert-press down-twist back thing...
Thoughts?
2009 mp3
2009 mp3
After a couple of days and the flashing red light in the speedo has stopped I have found the same thing. Just turning on the ignition and off again is enough to get the keyfob working again.
@gtdespatchcourier avatar
GTS 300ie, Honda Integra 700
The function switches off after 2 days to save battery. It works OK if you ride every day.
[ Time: 0.0082s ][ Queries: 4 (0.0027s) ][ live ][ 343 ][ ThingOne ]
