@oldschooot avatar
@oldschooot avatar
Heck of a thing to have to go fishing.....
The 50 or the 150?
Let's talk!
Has Piaggio sold so few LIBERTY's here in the States - or is it that Liberty owners are too busy smiling and riding to share their complaints?
Any way to learn how many LIBERTY's have been sold here since introduced in 2017?
nope
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
The air cooled units in the Sprint / Primavera / Liberty are bulletproof.
They've been running these same engines for 10 years now, and have perfected the recipe. Less to check, much less that goes wrong.
Have you got the Mymoover stateside? Saw a lot these recently in Italy being used by the postal service. Might be the liberty front end?
@nycsuburbscoot avatar
2024 Liberty 150 S
2024 Liberty 150 S
Just got my 2024 Liberty 150 S about two months ago and coming up on 100 miles. Zero issues so far. Added a top case and the side stand (side stand really should be standard - am very much enjoying having the option of side or center stand).
Have acquired the tools I need to do oil changes and valve adjustments. Zen and the art of scooter maintenance.
@25bikez avatar
2009 Genuine Stella 2T
@25bikez avatar
Although I'm trying to sell mine for health reasons, it's run perfectly for the year + I've owned it. I've got a top case, flyscreen with deflector, and Malossi Multivar kit with the white clutch spring. It's good for a steady 55mph (GPS) at less than WOT and will touch 62 on level ground after a long run up.
No issues at all (well, the irritating refueling touchiness, maybe).
@oldschooot avatar
@oldschooot avatar
No on the mymover- sounds like a Liberty for delivering pizzas!
I read some time ago that Piaggio has built something over 900,000 of this type big wheel, A/C scooter!
Thanks for your reply!
@oldschooot avatar
@oldschooot avatar
Please note that AF1Racing sells this for the LIBERTY. (pd $7 for it in 2017)
OEM Piaggio Workshop Manual - DL-1Q000412
Belt changes require some special tools.
Gaskets, washers, filter for the oils.
A new valve cover gasket and feeler blades for valve check. (some can be re-used, but why take the chance?)
Hardest part of a valve check, first time, for me was freeing the dam clamp on the breather hose to the valve cover. I didn't know a small screw-driver would spread it for removal! I cut it off!
That service manual down-load is a challenge, sometimes....as are the guys who wrote it! But better than nothing!
the CLAMP
the CLAMP
⚠️ Last edited by OldSchooot on UTC; edited 1 time
@oldschooot avatar
@oldschooot avatar
That case looks good on your white scooter.
Probably a good deal cheaper than the price of Piaggio's base plate and top case. I paid @$400 for the case and Plate.
Other than an Iridium NGK, I'm stock.
Never felt the need for more speed.
2024 Liberty 150 S
2024 Liberty 150 S
I downloaded the service manual from AF1 but believe it is now up to $17!
[ Time: 0.0105s ][ Queries: 4 (0.0021s) ][ live ][ 334 ][ ThingOne ]
