AndyPX wrote:
But if you want to run higher speeds with lower rpm it could be the way to go?
They are expensive, so Just wondered if anyone had taken the plunge.
5 speed transmissions doesn't automatically mean that it gives you an overdrive gear. Most of them are designed to have the same top gear ratio as a wider ratio 4 speed transmission, but what it's designed to do is give you a close ratio transmission in order to keep you in the power band. And usually when you do that, you can kinda upgear the clutch tooth in 5 speed transmission a little bit in order to lower your rpm a smidge.
All that is NOT worth it in a vespa! The transmission is not strong enough! If you have a high torque engine build, you're better off installing a 36t short 4 gear and a 24 tooth clutch.
