Now onto the electrics. There's some doco that says that the brake switch is usually closed unless opened. However the vna /Allstate pic that I found doesn't seem to support the theory
It looks like current comes off the coil, thru the switch and then into the globe
Plus I have the weird switch in front of the pivot, which means that pressing the pedal OPENS the standard switch
