Hi all,
There has been tons of posts around this subject but I can't find anything about the strange (or maybe not) idling I'm getting.
The engine: PX EFL Kickstart 125 with Malossi 177 Sport Aluminium Kit
Pilot Jet: 52-140 (2.69 ratio)
I've adjusted the mixer screw to the point the revs settle as best as I can get it. Any further in, the revs become more unstable, much further out it starts to get boggy. I've adjusted the idle screw for a reasonably low RPM. When I blip the throttle it picks up fine. It settles to idle quickly after revving.
However I get weak double pops every 4 or 5 strokes and it wont fully settle at idle. Idle revs tend to fluctuate in a cyclical fashion every 15-20 strokes.
I've tried it with the old 48-160 (3.33 ratio) idle and this is way too lean. I adjusted the mixture screw as far out as it goes. It doesn't settle at all and takes a long time for the engine to settle to idle after revving.
I've got a video, if anyone wants to see it, I can send a link to download it.
I've ordered a 52-120 pilot jet to see if that makes any difference. I'm not confident though as the standard procedure of idle adjustment seems to have worked apart from the odd idling.
Is this a sign of something wrong or nothing to worry about? Any thoughts appreciated.
