Vespa 300 supersport hpe 2024
Hi all!
I've now had my UK spec 300 supersport for nearly two months- loving it! However, I had a factory fitted alarm/immobiliser; it appears to switch itself off after being left for about 3 days, ie, the red light (not the dash one) no longer flashes. I can then approach with key fob in pocket ( at this point I have tried to disarm the alarm with key fob- no normal flashing of indicator lights) and start the scooter. When engine is switched off, I can then engage the alarm, ie the indicator lights flash and the red light in above the glove box flashes again.
Any thoughts gratefully received!
@rallygeek avatar
@rallygeek avatar
I had a Piaggio alarm on my uk spec bike and had similar issues after the bike sitting for a while. I couldn't find anyone who knew anything about them so sort of gave up trying to sort it out. If I was riding regularly it worked as expected and I used it but after a break it took some fiddling to reset it.
I now live in a city where I don't have to worry about an alarm on my bikes so have not had to install one.
Vespa GTS 300
Vespa GTS 300
Welcome to the forum and congratulations on your first post.
I know that at least the older versions of the original Vespa alarm system switch to a power-saving mode (so-called utility mode) after 72 hours.
Look for a manual for the original Vespa alarm system, it describes this in detail.
'Ere 'tis:
https://manuals.wotmeworry.org.uk/Alarm/
Important thing to understand:
the immobiliser is standard and is part of the ecu. it normally stops flashing the light after a couple of days but is still functional.
the alarm is the optional extra.
[ Time: 0.0087s ][ Queries: 3 (0.0023s) ][ live ][ 313 ][ ThingOne ]
