Hi guys,
I've been reading through the forum for the past few days, tried some things, but all to no avail.
My scooter has been filling air filter for the past few 1000 kms and stalled from time to time (rarely) when coming to a stop. But now it turned much worse. It's filling the air filter much faster. If I install a new air filter (oiled and then squeezed out all excess oil) it starts dripping out of the airbox after like 100 kms. If I open the airbox a lot of it comes out at the back (you can imagine the front pipe and the rear bulb being full at that time).
It starts and if it doesn't stall I can drive it normally. But if it stalls it takes much longer to start it again. While driving I really can't feel any difference from before - I think it runs normally. Maybe it has a bit less power, but I'm not sure. And from time to time it feels like it looses a bit of power for a second when driving like 50 km/s (so with throttle open just a bit). When I come to a stop there's a high chance it will stall again. And then it's pretty hard to start again (have to try a few times).
I remember it idling very stable at 1500 rpm in the past, but now it almost never reaches that rpm and acts pretty erratic.
https://youtube.com/shorts/O6FXiAyGZvk
I also started to hear decel popping when approaching 0 km/h, especially if I brake hard - I imagine that's when the clutch disengages and the idle loop should take over.
When dealing with that issue I noticed that it starts much easier if the crankcase vent hose is disconnected from the back of the airbox. I imagine that's because it has quiet a decent amount of blow-by and if the hose is disconnected it breaths much easier. I don't really know how much of a blow-by is normal for this engine.
https://youtube.com/shorts/ofYxBprwZAA
So, what I tried... replacing the air filter, removing throttle body and cleaning the butterfly and the walls around it. I also tried to spray some throttle body cleaner through the idle hole in the throttle body. Also tried to spray cleaner into the idle hole while running at idle, but it kills it quickly since it gets all the air through that hole when idling. I replaced the spark plug.
I checked for air leaks but I can't find any. Did the compression test and it shows something very low - like 78 psi, but it's not relevant because it has a release-valve or something... that's what I read on the forum.
At this point I'm out of ideas. And considering the blow-by volume, I think the piston is cracked. I would be glad to hear some of your ideas. I know there are hundreds of topics regarding issues just like that, but I have a feeling I'm missing something... I would like to avoid tearing it apart and finding that it's not the piston.
Maybe it's just a failing coil or something... I also read that someone had idle-stalling issues and solved it by replacing the coil. I don't know.
The scooter has 31k kms on it.
I'm grateful for any suggestion.
12
