wbdvt wrote:
First let's get terminology correct: that is the exhaust bracket not swing arm
Use lots of penetrating oil and heat the bearing. Patience as it will take time. You can get a bearing puller from Harbor Freight and get it on there and put some pressure. Another way is to put axle nut on and tap with hammer
Eventually you will hear a pop and will come loose.
Replace the bearing in the exhaust bracket
Ok I must be missing something all the previous posts o the bearing vs bushing terminology.
No where did I refer to the exhaust bushing as a bearing. I said the bearing in the exhaust bracket. I know the difference
In fact, I have it on good authority that, if you watch The Big Scoot when released, you will see me on the ground in a gas station parking lot in Navajo Nation on the 2023 Cannonball replacing said exhaust bushing
