04' P200e
04' P200e
On my project PX Im looking to simplify the wiring so am using a Axle Joost B-Box (MotoGadget style brain).
To keep things simple I elected to buy a 2-wire PX Ignition Barrel - all it has to do it give signal to trhe brain to turn on, but when I put a multimeter across the wires it says in the ON position there is not circuit connection - What The? emoticon . How does this thing work?! Does the four wire version of the ignition work differently?
Ignition picture
Ignition picture
Axle Joost B-Box unit
@safis avatar
@safis avatar
Two wire lock…
Green - Black.
OFF - Contacts closed, kills the engine.
ON - Contacts open, engine can be started.
Four wire lock…
Green - Black same as above.
Red - White.
OFF - Contacts open, DC / battery side is disconnected.
ON - Contacts closed, DC / battery side is live.
04' P200e
04' P200e
Cheers for that AsFiS
I think I need to go back to buy a four wire barrel Facepalm emoticon
Oh well it's just money right..
Kind of a shame as if it closed the circuit ON it would have been perfect for the B-Box install
SaFiS wrote:
Two wire lock…
Green - Black.
Four wire lock…
Red - White.
[ Time: 0.0090s ][ Queries: 4 (0.0021s) ][ live ][ 334 ][ ThingOne ]
