04' P200e
04' P200e
Hello,
I got a SIP VNA/VNB Speedo and SIP Fuel tap for a build - but I cant workout what the extra (orange) wire is for? What The? emoticon
Anyone have an idea?
Speedo all hooked up with extra wire..
@safis avatar
@safis avatar
If I recall it's for battery / charge voltage reading, connects to +12V DC. Leave disconnected if no battery…
parallelogramerist
parallelogramerist
This is how i wires up my Allstate VNA's SIP speedo to my 12VDC (with a battery). As Safis said, the orange wire is for the voltage reading.
And good luck fitting the speedo in the VNA's cramped headset. It's NOT a fun project.
EDIT: by the way, i ended up deleting the fuel level wires from my SIP speedo. I was running out of room for wires to pass through the steering column, so i simply cut out those wires. I never had my heart set on having a fuel gauge in the first place, so it didn't bother me whatsoever to remove it.
⚠️ Last edited by whodatschrome on UTC; edited 1 time
04' P200e
04' P200e
Thanks for that, and much appreciation for the wiring diagram. The other question i have posted here is for a 2 wire PX ignition barrel and your diagram has provided some clarity Clap emoticon
parallelogramerist
parallelogramerist
Here some more reading on my VNA SIP speedo
thinking about installing a SIP digital speedo
[ Time: 0.0118s ][ Queries: 5 (0.0035s) ][ live ][ 335 ][ ThingOne ]
