⚠️ Last edited by Tierney on UTC; edited 1 time
I recently picked up a P200. I don't know what the future will hold, but as of now, I just want to make it a running and safe ride. And while I watch in fascination of how these engines can be taken to a much higher level, I don't possess the knowledge or funds to do so. I am, however, very interested in the concept of O-tuning which I think means doing the most with what you already have. I have seen mentions of this thru different threads over the years, so finally to my question: is there a definitive thread, video or information source on this subject relating to these 2stroke Vespa engines? This would of course make for a great Wiki subject like the one presented on the SI jetting and tuning guide. It would be a lengthy endeavor, I'm sure, and would almost require the patience of Job and wisdom of Solomon. Anyhow, any thoughts or direction would be appreciated. Thanks.
![]() 1961 VS5T, 1981 P200E, 2003 Malaguti F12 Phantom,Rigid Frame Chopper, 2001 Harley FXDXT
Posts: 1633 Location: Ventura, CA |
Tierney wrote: I recently picked up a P200. I don't know what the future will hold, but as of now, I just want to make it a running and safe ride. And while I watch in fascination of how these engines can be taken to a much higher level, I don't possess the knowledge or funds to do so. I am, however, very interested in the concept of O-tuning which I think means doing the most with what you already have. I have seen mentions of this thru different threads over the years, so finally to my question: is there a definitude thread, video or information source on this subject relating to these 2stroke Vespa engines? This would of course make for a great Wiki subject like the one presented on the SI jetting and tuning guide. It would be a lengthy endeavor, I'm sure, and would almost require the patience of Job and wisdom of Solomon. Anyhow, any thoughts or direction would be appreciated. Thanks. |
![]() 79 P200E (Ruby), 62 Allstate (B-62), 63 VBB (Storm)
Posts: 4741 Location: Florence, OR |
I think this is a GREAT idea!
WhiteOneRacing has a great vid on the subject. They changed its title recently and it seems that they have a series of other videos (carb tuning, etc) but I haven't checked them out yet. But the O-tuning vid is great, and I can attest to it's validity. I did what they recommended and it really woke up my P200. I did differ on the head though. They sanded theirs down and added a gasket. I just sanded a little. |
qascooter wrote: I think this is a GREAT idea! WhiteOneRacing has a great vid on the subject. They changed its title recently and it seems that they have a series of other videos (carb tuning, etc) but I haven't checked them out yet. But the O-tuning vid is great, and I can attest to it's validity. I did what they recommended and it really woke up my P200. I did differ on the head though. They sanded theirs down and added a gasket. I just sanded a little. |
Just keep in mind that when the power goes up, the reliability goes down. I would say bare minimum for upgrading the rest of the engine to an O tune would to also install a fancy billet clutch, GS piston, and at LEAST $100 of individual jets and carb slides. From there you'll also want to make sure you're front brake is in tip top shape. Also go through your entire transmission and make sure there's zero nicks or chips in the loose transmission gears when you go to replace the cruciform. Also leave yourself enough space here on the modern vespa website to have a 3~6 page thread on why you're having difficulties dialing in the jetting correctly.
just sayin |
O-tuning is harder than putting together a kitted engine. It might be cheaper, but it's not free just because you are working with what you have. If you are new to Vespas, getting a stock engine running reliably will keep your hands full. When you've got that down, you will have a better idea of what your next project will be. Take small steps and see how like it.
Positive
I was thinking about O-tuning, and to add to WhoDats list:
Carb bowl passage opening to allow more fuel. Fast flow fuel tap Short 4th (I'm not running one yet) Timing. MrFreakMoped.has many videos on the subject as well as WhiteOneRacing. It'd be good to identify the specific vids pertaining to O-tuning from these two YouTube channels... |
Thanks for all the suggestions, just what I was for. I'll check out the links and try to keep an open mind. This is all just curiosity on my part with a possibility of using some of these techniques on a future project.
![]() PX125,200, T5, SS180,TS125 and some more...
Posts: 204 Location: Paris, Taxes! |
Some pics of a o-tuning 200 in the German way of dremelling! Just scroll down the page:
https://www.facebook.com/groups/107236579867807 |
