GT200
GT200
Hi, can anyone give me a step-by-step how to re-assemble the kickstart on my 1950s Douglas?
I can't figure out what the screw that comes through the casing is used for... (see pointer in pic below).
Thanks!
Miles
@bajarob avatar
@bajarob avatar
Miles, get this and all your troubles will disappear.
GT200
GT200
Thanks BajaRob that's a great idea!
@bajarob avatar
@bajarob avatar
I got mine from SIP. Truly indispensable for our wideframes.
@gickspeed avatar
@gickspeed avatar
no.
Remove the index screw
have the O-ring, kickstart segment, return spring, and kickstart bush as one unit. Install into case. now install the index screw.
Then attached your kickstart lever. rotate your lever to maximum. now install the 2 small springs and toothed gear.
last, install circlip.
@bajarob avatar
@bajarob avatar
Here's some goodies from my Douglas book.
GT200
GT200
Genius thanks so much guys. I didn't know there was a book! I've been using my Haynes manual which is great for my VBB but no good for the wideframe.
@bajarob avatar
@bajarob avatar
Which model is yours, the 42/L2 or the GS?
@gickspeed avatar
@gickspeed avatar
engine has a curved kick lever and a 3 speed shifter.
@bajarob avatar
@bajarob avatar
Duh, he's got the 125! I can be a dummy sometimes.😉
@bajarob avatar
@bajarob avatar
Maybe this will be useful.
GT200
GT200
Serial number makes me think it's a Douglas G is that right?
If so that would mean the carburettor should be Amal 361/200, which I've never heard of. The ones I've got are SHB16.16, Dellorto 17B and 18C. Can I use any of these?
@bajarob avatar
@bajarob avatar
The Rod model of 1951-53 uses the same carb as a G. Stoffi's Garage has Polini CP carb conversions for your style engine in a 17.5 and the 19 for the 2TP cylinders. So one of yours could work.
[ Time: 0.0114s ][ Queries: 4 (0.0051s) ][ live ][ 334 ][ ThingOne ]
