@cogind avatar
Vespa GTS 300
@cogind avatar
Vespa GTS 300
Greetings!
About two months ago, I took my bike out for a ride on some twisty roads nearby. It goes through a forest, lots of hills, fun. The last part before it gets to a straight road home has been recently resurfaced with new black top. About two or three blocks.
The whole ride takes me about an hour. Under my bike there was a little bit of oil coming out of the front "shark gill" on the right when I got home. I noticed it about an hour later, so there was a quarter size splotch on the ground. There was also black dust from the new blacktop on the bottom of the bike. I didn't think much about it, figured it was kicked up from the road surface. Maybe I ran over some oil from a car. Cleaned it up, washed the bike, and have checked the area every few days, nothing leaking.
Yesterday, I did the same ride, and same thing: a bit of oil under the right side of the bike.
Oil level is fine. No oil in bubble. Bike didn't over heat. Runs great. Took out the pet carrier, no oil leak or spray. Stuck my hand under the cylinder and the gasket for the valve cover is dry. Oil filter is intact and on properly and tight. No seepage from drain plug
I cleaned it up, and took it out up the coast and back, about an hour. Stopped for groceries, no oil under the bike.
At the last service, under warranty, Robot replaced the oil sensing switch. They also did the 6k service early at 4600. It's got 8700 or so miles now.
Any ideas? Thanks.
And will give Scooterwest a shout out tomorrow, just wanted to see if the collective here might know.
first look - maybe dirty water not oil? maybe road grime gives it that colour?
@cogind avatar
Vespa GTS 300
@cogind avatar
Vespa GTS 300
It's oily. You can see the stain on the garage floor. It was dry weather, no puddles.
I also checked the coolant level and in the battery box back in April, all normal.
[ Time: 0.0104s ][ Queries: 4 (0.0038s) ][ live ][ 313 ][ ThingOne ]
