@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
The "race" pipe, not the newer one with twin tip dB killer. Can I get a favor? I need a measurement of the length of the sleeve from edge to edge. TIA
@erver avatar
Vespa Sei Giorni I 2018 | Vespa PK50 1987 | Vespa 50N 1968
@erver avatar
Do you mean this one:
https://akrapovic.com/en/moto/product/20116/Vespa/GTS-Super-300-Sei-Giorni-Tech/2018?brandId=39&modelId=283&yearId=4918
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Yes, that one. Possible to get edge to edge length measurement on the sleeve?
These are discontinued from Akra but I think I may have a workaround.
@erver avatar
@erver avatar
I will do that 👍🏼
Just to be sure, what do you mean with sleeve?
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
The main body of the muffler less the end caps.
Akra sells this as a repair part and I think I found a muffler from another bike that I can convert to fit the GTS by swapping out the sleeve. Just need to make sure the length is the same.
@erver avatar
@erver avatar
Ah, check!
The length of the main body is exact 35 cm's.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Exactly what I needed, thanks.
@erver avatar
@erver avatar
You're welcome
[ Time: 0.0144s ][ Queries: 4 (0.0068s) ][ live ][ 343 ][ ThingOne ]
