@wetspeed avatar
GTed4LIFE
'05 GT200
GTed4LIFE
@wetspeed avatar
'05 GT200
Hi Nile,
I have been thinking of removing most of the fan blades from the stater side fan as this is use to push air into the Cat exhaust. I would remove all but think the electrics may need some cooling on a street motor.
Since I no longer have a cat exhaust, I also plan to reroute the crankcase vent to the exhaust with a ck valve so that a vacuum is created therefore cause less resistance to piston travel on the intake and power stroke.
Thoughts
Jim
BV 500
BV 500
nile, performance...
Someone familiar with the cooling flows of that fan will have to advise you on blade removal (be sure of everywhere that cooling airflow goes). Crankcase venting is usually connected to somewhere in the intake system, isn't it? Unless you've created a venturi type device, it would seem that the exhaust system would involve only pressure (which you do not want to hook to the crankcase).
@nyle avatar
@nyle avatar
Re: Nile, Performance question 1
Jim I don't get what you are talking about on the Stator? got pics? I know there are fins inside the flywheel!
just vent the crankcase up higher on the frame itself and put a uni filter on the end. I don't know if building up presure on the inside of the case would be a good thing.
Nyle
wetspeed wrote:
Hi Nile,
Thoughts
Jim
@wetspeed avatar
GTed4LIFE
'05 GT200
GTed4LIFE
@wetspeed avatar
'05 GT200
Nyle
High performance engine builders do this all the time. The hose from the crankcase is placed on the valve cover and then on the exhaust at an angle opposite of the flow and in a way the exhaust pulls a vacuum on the crank case.
The fan on the stater side is the pump that push air into the exhaust. I will get some photos etc. What I need is a longer rod for the 200!!
@nyle avatar
@nyle avatar
what's a longer rod gunna do?
@spock avatar
2002 ET4 & 1980 100 Sport
@spock avatar
I have a couple ideas what a longer rod can do...
@bendcyclist avatar
2006 GTS 250ie in Silver
@bendcyclist avatar
Hahaha
I am always getting junk emails for a "longer rod".
Actually some of them are kinda funny. The names they use are hilarious.
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
I am really happy I had the operation and so is the wife.
@glasseye avatar
@glasseye avatar
So do you end up higher compression?.......or lower...
Razz emoticon Razz emoticon Razz emoticon Razz emoticon
R
8)
@wetspeed avatar
GTed4LIFE
'05 GT200
GTed4LIFE
@wetspeed avatar
'05 GT200
2 things: Keeps the piston in the high pressure area longer (crank rotation)and it acts as a longer lever increasing the force from the piston.
2 motors with the same CI and Compression, the one with the longer rod will make more HP and Torque.
I will need a custom piston but that will bring even more to the table. Gas ports to seat the rings better, lighter weight etc
@nyle avatar
@nyle avatar
just deck the cylinder top. but you gota mess with the timing chain. I am working on a custom piston right now for my project. It's gota be tuff!
@wetspeed avatar
GTed4LIFE
'05 GT200
GTed4LIFE
@wetspeed avatar
'05 GT200
Won't do the same thing as the longer rod.
In addtion, I plan to up the compression to 12.5 / 13 to 1 add the malossi valves, cam, port the head, longer intake with exhaust to match total tune length and that larger carb, remove the compression release and try to reduce the rotating mass as much as possible.
@scooter_west avatar
Sponsor
Sponsor
Nyle
I believe you would put a one way valve called a PCV valve on the line. The Vino125 owners says this helps a bit.
-Max
@wetspeed avatar
GTed4LIFE
'05 GT200
GTed4LIFE
@wetspeed avatar
'05 GT200
Hi Max,
Yes it is very similar. It is accutally a one way check valve made of metal to handle the heat. I am looking for a good artical to post about htis for Nile to review...
[ Time: 0.0171s ][ Queries: 3 (0.0067s) ][ live ][ 313 ][ ThingOne ]
